dlucas10
Nov 03, 2017Follower
Circle loses Premium
Hello! I have the Circle setup, and it seems to have lost the premium features. When I’m in the Circle app, and I restore iTunes purchase it says it can find the subscription but when I look in iTu...
- Apr 13, 2018Turns out I had an active Circle GO subscription, instead of an active Circle Netgear Premium subscription ( I don't remember exactly when I started Go, but might have been on initial setup of the Circle app). The 2 subscriptions aren't hard to confuse with each other in the Google Play app. Anyway, when I re added the Netgear premium subscription all the normal functionality came back.
harlannorth
Dec 22, 2017Aspirant
I'm having the same issue with the R7000P -- if I try to buy it again I am told that the recurring purchase already exists, if I try to find it can't find my purchase.
Is there a solution?
