dlucas10
Nov 03, 2017Follower
Circle loses Premium
Hello! I have the Circle setup, and it seems to have lost the premium features. When I’m in the Circle app, and I restore iTunes purchase it says it can find the subscription but when I look in iTu...
- Apr 13, 2018Turns out I had an active Circle GO subscription, instead of an active Circle Netgear Premium subscription ( I don't remember exactly when I started Go, but might have been on initial setup of the Circle app). The 2 subscriptions aren't hard to confuse with each other in the Google Play app. Anyway, when I re added the Netgear premium subscription all the normal functionality came back.
WaterlooStu
Mar 28, 2018Tutor
Same issue here ... This has been going on since end of December. I'm still being billed, but app doesn't show premiun subscription. Still shows the little blue guft icon on top right.
I'm just finally getting a chance to find a solution.
WaterlooStu
Apr 13, 2018Tutor
- DexterJBApr 24, 2018NETGEAR Moderator
Hi all,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- WaterlooStuApr 25, 2018TutorMy issue is resolved. My last message describes what sorted my problem out.
