CReynard
Jun 23, 2017Aspirant
Compatibility Issues
I just purchase the netgear AC1900. I currently and using the hitron CDA3-35 modem. For some reason or another it's not getting the internet to the router to project the wifi. Just wanting to know if ...
CReynard
The nighthawk smart wifi router
- netwrksJun 23, 2017Master
Power off your modem. Wait about 5 minutes, then power your modem back on. Wait for you modem to come back online, then ***power on the NG router. Run Internet Set up Wizard (page 22 router manual). ***Before you power on your NG router, ensure you have a Ethernet cable (min CAT5e / CAT6) cabled from WAN / Internet port from the NG router, to the Ethernet port on the Hitron modem. Also, Ethernet cable a laptop to a LAN port on the NG router.
Don't forget to change the default router login password and default wifi passphrases.
