Help
4 Topicsunable to access guest account from app
Since the update from the old Genie App (purple one) to this blue one I've been unable to turn the guess account on and off from my app. When I swipe it across then push save to change settings it says " unable to change settings. My router model is DGND3700v2. I am able to enable and disable guest account on my PC computer but not the Genie app anymore. Please help as I loved this app when it was the old version, it worked so well. Look forward to your reply. Many thanks, Paula.2.7KViews0likes1CommentCompatibility Issues
I just purchase the netgear AC1900. I currently and using the hitron CDA3-35 modem. For some reason or another it's not getting the internet to the router to project the wifi. Just wanting to know if it's a compatibility issue and need to upgrade the modem.3.8KViews0likes3CommentsRemote Access For Dummies
I apologize if this is asked and answered somewhere in this maze of a website, but I have been going in circles for 30 minutes trying to find the simplest of answers: how? The other day, I was at work and the router needed rebooting. No one was home except for my wife and she didn't know how to do it. Finally, in desperation, I told her just to unplug the thing, wait 30 seconds or so, and plug it back in. When I dowloaded Genie, I saw something about "Access your router from anywhere". So I thought it might be a good idea to learn how to do it, in case we had another problem and I was at work, I would know exactly what to do. So tonight I came here to do a little research. Little is the key word, because I can find precious little information on how to do it. I can't even find the freaking login page, I don't know if there is a login page, or if I'm supposed to access my router from the Genie program. So, I'm asking that someone give me a "Remote Access For Dummies" lesson. I have a laptop computer, Windows 10, with Netgear Genie installed on it. Obviously, I have created a Netgear account, or I wouldn't be typing this right now. Also, if I can do this on my phone, I do have the Netgear Genie installed on it as well. It is an Android phone, an LG G4 to be exact. Anyone who would like to tackle this, or at least point me in the right direction would be my hero. Thank you.Solved6.9KViews0likes2CommentsR6300v2
I have repeatedly tried changing the password on my router it takes me to my security page I input everything in then it takes back to my the page to input the router numbers and it goes back and forth it never takes me to the oage to reset my password can you help I tried to ask you online that even failed other than throwing the thing out the window I dont know what to do and I'm pretty smart where it comes to these thingsSolved4.7KViews0likes2Comments
