CReynard
Jun 23, 2017Aspirant
Compatibility Issues
I just purchase the netgear AC1900. I currently and using the hitron CDA3-35 modem. For some reason or another it's not getting the internet to the router to project the wifi. Just wanting to know if ...
CReynard
The nighthawk smart wifi router
netwrks
Jun 23, 2017Master
Power off your modem. Wait about 5 minutes, then power your modem back on. Wait for you modem to come back online, then ***power on the NG router. Run Internet Set up Wizard (page 22 router manual). ***Before you power on your NG router, ensure you have a Ethernet cable (min CAT5e / CAT6) cabled from WAN / Internet port from the NG router, to the Ethernet port on the Hitron modem. Also, Ethernet cable a laptop to a LAN port on the NG router.
Don't forget to change the default router login password and default wifi passphrases.
