Midnitejlr
Feb 25, 2023Aspirant
Correcting CAX30 connectivity
Since trying to reconnect to the internet I can no longer access my nighthawk app. Using the reset and default password do not work. Any suggestions?
Can you access the modems web page with a wired PC and web browser?
- MidnitejlrAspirantYes I can with a MacBook older one
What mobile device do you have the NH app installed on?
What FW version is loaded on the CAX30?
Other than the NH app not working, is the CAX30 working otherwise?
The devices I am trying to use the NightHawk app on are iPhones; a 7series and a 10 series. Still can not enter the app with an admin password even after resetting the modem.
Be sure any WiFi private IP address features are disabled on Apple devices.
If all else fails, submit a bug report:
