doxa2u
Jun 01, 2017Aspirant
Desktop Application Netgeargenie will not except any password attempts
I can access my router through the browswer no problem!!! My modem was replaced due to faulty previous one. When I launch the Desktop Appliacation Netgear Genie no password will work. I have...
DexterJB
Jun 08, 2017NETGEAR Moderator
Hi doxa2u,
You can try to change the LPC (Live Parental Controls) password through the forgot password option if you have access to the email that you have registered. You can go to https://netgear.opendns.com/sign_in.php.
Dexter
Community Team
- DexterJBJun 18, 2017NETGEAR Moderator
Hi doxa2u,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- doxa2uJun 19, 2017Aspirant
No go ... it is useless ... nothing works ... I can go on line through a browser and access the router. But I cannot access the parental controls through Genie app .. also I cannot access router settings through Genie App. I can go to the router, 192.168.1.1 and put in admin and default password .. no problem .. Genie app is useless cannot access through it
- DexterJBJun 22, 2017NETGEAR Moderator
Hi doxa2u,
1. What is the model number and firmware version of your device?
2. Please try using another device (Android, iOS, another computer).
3. Are you getting an error message? If yes, what is the error message?
4. Please try uninstalling and re-installing the app.
5. Have you tried resetting the router?
Dexter
Community Team
