glsrdaz's avatar
glsrdaz
Device Manager shows white background & stupid counts
App ver 2.23.0.2673
Firmware v 1.0.3.32
Normal black background now replaced by white screen with no band groupings. Device count may be accurate or may be 0, -1, etc.
Initially noticed Feb 5, 2023.
Occurs on numerous devices around the house.
What's up folks...truly a step backwards. I left Netgear in the later 2010s because of stupid interface behaviors and now they're back?
  • michaelkenward's avatar
    michaelkenward
    What Netgear device are we talking about here?
    The firmware version is not much help as it could apply to various devices.
    And which app is this? iOS? Android?
  • FURRYe38's avatar
    How about a screen capture to post what your seeing...
    glsrdaz wrote:
    App ver 2.23.0.2673
    Firmware v 1.0.3.32
    • Router: NightHawk MR70
      • Firmware: v1.0.3.32
      • App: v2.23.0.2673
    • Phones x 2: Samsung Galaxy S20
      • Android v13
    • Tablet: iPad MYL92LL/A
      • iPadOS v16.3
    • Tablet: Galaxy Tab S5e
      • Android v11
    • Tablet: Galaxy Tab A
      • Android ver currently unavailable
    • Windows 11 Pro x 2
      • v22H2
      • OS build 22621.1265
      michaelkenward
      That's not what I see on my Android, same version, another Samsung.
      Could it be a setting on your Samsung device? I can't see anything app specific.
  • screenshot of Device list (white background) attached
  • Thanks for the quick reply.
    The  display you present is the displayed characteristics my devices showed from Aug 2022 thru approx Feb 5, 2023.
    I currently get the white model on all the devices listed in the thread...Samsung phones & tablets, iPad, Windows 11 Pros.
    • FURRYe38's avatar
      Seems that for the MK series systems, this is by default with a White theme for the Device Manager. I see same thing on my MK series system as well on Android. If I change over to a non MK system, I have a XR700 online on a separate line, the device manager display is dark themed.
      I'll pass this on to NG and see what there intended design is going to be for the MK system or if this is just a bug.
      DarrenM KevinLiT
        michaelkenward
        Not here.
        I have a mix. No white theme on MK or R7XXX. That's "Connected Locally".
  • Anywhere Access & Connected Locally both show the White Blight...whether Samsung Galaxy phones, iPad tablet, etc.
    Home & Guest SSIDs sameo-sameo.
    I'm a solid Democrat, CRT isn't a factor in my house.
    Thanks again for your active involvement folks.
    After 40+ yrs of interface design I've simply lost the love/quest.
      michaelkenward
      Guess what. My attached devices have just gone negative on me. While background.
      I did nothing to provoke this invasion of my Android devices.
      I blame you lot.
      I have also seen some freaky behaviour with Anywhere Access, but that is for another conversation.
  • FURRYe38's avatar
    Testing local or AA yesterday didn't show any differences. Both showed WHITE.
    Question, has Smart Parental Controls been enabled or ever been enabled with in the NH app?
    glsrdaz michaelkenward
    • glsrdaz's avatar
      glsrdaz
      No Parental Control Settings in use on my side of events.
      • FURRYe38's avatar
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Don't set it up using the NH app. After the MR is setup, then log in to the NH app and check the device manager.
  • So if I'm understanding things properly I'm 6 months back-in-the-saddle with NetGear and I've just recently lost the dark theme and stuck in the mire of white (color is one thing, the loss of groupings, on/off switches etc is another).
    Bummer plus.
    Again thnx so much for the quick responses folks.
