ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
Retired_Member
Oct 04, 2016I am having the same situation. All my devices are showing bypass login so I can not change them. This is very disappointing as LPC was one of the reasons I purchased this unit. I have also seen other recent posts about LPC bypass issues - please fix.
I am on most current firmware 1.0.7.2 - I am running most recent Genie version 2.4.32. Also it is not feasable nor possible to load the Genie software on all my devices and disable bypass setting. Acctually I have tired this on several of my devices and it dosnt appear to work anyway.
Are LPC filter settings stored on router? Would a reset to factory reset filter settings?
- ElaineMOct 05, 2016NETGEAR Employee Retired
Can you provide me steps on how can I reproduce this?
I have enabled LPC, tried to browse from a device and it's being blocked by LPC.
While LPC is enabled, I have turned on Access Control and it's still working as it should.
Retired_Member LPC Settings are not affected when you reset the router. The settings are in https://netgear.opendns.com
- Retired_MemberOct 06, 2016
I can not tell you becuase i do not know how / when it happened. I need to reset my lpc settings. As you can see I am not the only one that is having this issue. Please advise on what i need to do to reset.
- bazanOct 06, 2016Aspirant
Apparently I have the same problem started around 2 days ago... I was trying to modify individual device access setting via the network map. and discovered there are some device "stuck" at "bypasslogin" and no matter what I do i.e. via web... going opendns... nothing can be modified and is still stuck at "by pass login" . I cannot changee to "minimal" or "low" etc...
- trevsterxOct 06, 2016Tutor
Exactly same problem here. Both child phones are stuck on Bypass login and I dont have any Bypass login accounts. I can't find anyway to reset them so.
- ElaineMOct 06, 2016NETGEAR Employee Retired
Kindly take a look at the DNS address on the router if it's the DNS address for the LPC.
The DNS address plays a big role for the LPC to take effect.
You can verify the DNS under Setup > Internet Setup on the admin page of the router.
The DNS addresses should be 208.67.222.222 and 208.67.220.220.
