ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
bazan
Oct 07, 2016Aspirant
Not in my case. the same msg comes up if i try changing it using my android phone app. asking me to disable bypass login for the device first
ElaineM
Oct 07, 2016NETGEAR Employee Retired
Ok guys, I was able to replicate this now.
It seems that the filtering mode will only apply if you use the Genie app on the iOS and not on desktop Genie.
Not sure if it's the same thing with Genie app on Android, can somebody confirm?
- trevsterxOct 07, 2016Tutor
I'm using Android so yes it is on that too.
Cheers,
Trev.
- ElaineMOct 07, 2016NETGEAR Employee Retired
Hey Trev, sorry just to clarify, you can adjust settings on the Android Genie app and it works? Or the Android Genie app doesn't work same as the Desktop Genie?
If I change the settings in the genie app on the phone then I cant adjust them on my PC. But once I've put them back on the phone then the PC can control them again.
