ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
pgolgan
Oct 12, 2016Aspirant
Any idea when you will have a fix for this problem? I've been checking this thread for days
JPCubish
Since the silence is deafening from NetGear, I will share my work around. Steps:
1. Uninstall most recent Genie from device (my case Android)
2. Google search Genie version 2.4.26 (older version)
3. Install older version on device and reset the network devices with the "Bypass mode" set.
TURN OFF AUTO UPDATES on your device or you will get the new hosed Genie version back again.
Have a nice day !
- BlkjakOct 12, 2016Tutor
Makes sense JPCubish.....might be tough on IOS though.
