ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
pgolgan
Oct 12, 2016Aspirant
Thanks JPCubish. Unfortunately I have an iPhone so I can't get the previous version.
- JPCubishOct 12, 2016Aspirant
Try to do the same steps but for Apple. A Google search should yield a way to role back, even for Apple. Keep mind, the Android version I mentioned above may NOT be the same for Apple, so try to research the versioning for your product.
Good luck.
