ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
RedCheetah
Oct 21, 2016Aspirant
Yeap same problem since iOS 10 update I think. Maybe a coincidence but it's a major pain. Please fix it asap Netgear.
- MoreliaOct 25, 2016AspirantHas anyone been able to obtain an update for a fix from Netgear on this? I spoke to them last week, and initially they denied there was an issue, and suggested everything mentioned in this thread as a fix. After pushing them a bit (and numerous requests to put me on hold to "check with others"), they confirmed it was a problem that needed to be addressed. Hopefully someone, somewhere is able to put enough pressure on Netgear to fix their own product. I am sure I am not the only one that purchased their product (Nighthawk X6) in part due to the parental control capabilities.
