ZeroOne
Oct 03, 2016Guide
Devices on my network stuck in Bypass login but I have no bypass login account
Hi all, Thanks for reading. I had Parental controls working fine for a year. Now disaster. The router has changed the access level of a number of devices on my network. It has set a number of the...
Boris2014
Nov 18, 2016Guide
Still problems this end - found my teenage son on his laptop able to access absolutely everything. On the network his laptop had bypass login against it. Changing that resulted in a message telling me to log out of the bypass account first. I have no bypass account.
Please fix this Netgear - you've known about this issue long enough and nothing is being done that I can see, to fix the problem.
ElaineM
Nov 19, 2016NETGEAR Employee Retired
Boris2014 What's the exact model number of your device?
What's the Genie version you're using on your laptop and on your mobile device?
- ZeroOneNov 19, 2016Guide
ElaineM Hi Elaine, I'm the OP. Nothing has changed - still does not work. Still can't get devices including Chromecast and printer out of Bypass mode, and I still don't have a bypass account. Android Genie App v2.4.38 (latest on playstore), Firmware v1.0.7.2_1.1.93.
This is a serious security flaw and is going unaddressed for a long time. As others have reiterated, it needs to be fixed.
Please let us know when this is scheduled to be fixed?
- MoreliaNov 23, 2016Aspirant
ElaineM Yes, I am still experiencing the same issue as everyone else. This needs to be fixed, as it has been affecting your customers for months now, with no apparent attention from Netgear. I have the latest version of the Genie app, and no ability to set parental controlss on my families devices. When a company advertises specific capabilities, but the product fails to meet those capabilities, it leads to class action lawsuits.
- PascaNov 28, 2016AspirantHello everyone,
I had this problem, I solved by resetting the modem-router (D7000), but doing the tests I discovered something much more serious, the Live Parental Control does not work fine.
Setting the default security level to high, and that of individual network devices on the default security level of the router, everything seems to work correctly, but when you change the security level of the individual devices to a different security level (high, moderate, low, minimum and none) LPC only protects against phishing. You can do the function test here: https://support.opendns.com/hc/en-us/articles/227986567-How-to-Test-for-Successful-OpenDNS-Configuration-
Too bad, I was fully satisfied with my D7000, a few months ago it worked perfectly.
I tried to contact support in my country, but I did not get satisfaction.
I do not trust most of this modem, and more generally of Netgear products.
I solved the problem by contacting Amazon for allowing me to return my device and refund of the price paid nine months ago. Great Amazon !!!
Excuse my (google) English.ByePasca
- KupthebuckeyeDec 07, 2016Guide2.4.20 appears to be the version on my Laptop.The Version on my Samsung S7 (Verizon) phone is Firmware Version: V1.0.0.44 / Version: 2.4.38Please help me as this issue is still an issue.The Bypass login just appeared out of nowhere and is preventing me from making any changes to the Parental Control Filters.That's the ENTIRE reason I purchased this EXPENSIVE router and paid HUNDREDS to have Geek Squad set it up for me.If you can NOT repair this issue, am I going to get a full refund for my product?
