DmitriKaradayan
Jul 27, 2017Aspirant
DGN2200v4 as a leader for repeater
Good day! I have the DGN2200v4 router and I'd like to connect to it my second wi-fi router - Zyxel Keenetic Start as a repeater. But I can't force them to work together. It seems, that DGN2200v4 c...
michaelkenward
Jul 28, 2017Guru - Experienced User
The DGN2200v4 is a modem/router, which complicates the matter.
Are you trying to create a repeater or an access point? In other words, is the connection from the DGN2200v4 to the router supposed to be wired or wireless?
DmitriKaradayan
Jul 28, 2017Aspirant
I'm trying to create a repeater. The connection supposes to be wireless. Wherein Netgear will be as a "Master", and Zyxel as a "Slave".
- michaelkenwardJul 28, 2017Guru - Experienced User
If you want the DGN2200v4 to receive wifi and pass it on to other devices, you are probably out of luck. Only some routers do that.
You can turn it into a wired access point. See page 85 of the manual.
- DmitriKaradayanJul 28, 2017Aspirant
Not that way.
I want the another router (Zyxel) receives wi-fi from DGN2200v4 and pass it down. For many other routers it is not necessary to make any additional steps. But instructions from internet say that I need to turn on this function in configuration.
For instance look at the screenshot from the internet for another Netgear Router.
http://s002.radikal.ru/i199/1302/91/862431486b9e.jpg
There is a special option in menu "Wi-Fi repeater function". In Russian "Функция ретрансляции Wi-Fi".
In my web-configurator there is no such option.
- DmitriKaradayanJul 30, 2017Aspirant
I found interesting idea at the topic about WNR2000v4. It's here.
It says that in the new firmware there is no Wireless Repeating Function (security needs). As a solution, it is proposed to downgrade the firmware.
Can this solution be aplicable to my router?
May be somebody has an older firmware on his router. Is there "Wireless Repeating Fuction" in the menu?
