× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNR2000v4 as Wireless Repeater?
rroche
I have a Netgear wireless router in my basement with the Cable modem.
I have a second Netgear Router (WNR2000v4) router that I would like to setup as a wireless repeater on the second floor.
In chapter 7 of the user manual it indicates the option to enable this is under Advanced | Advanced Setup | Wireless Repeating Function
However, in my router, under Advanced | Advanced Setup there is no Wireless Repeating Function??
Does this need to be enabled somewhere else to show up?
I am on firmware v1.0.0.64
Thank you for any help!!
Model: WNR2000v4|N300 Wireless Router|EOL
Message 1 of 6
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: WNR2000v4 as Wireless Repeater?
Welcome to the community, @rroche
The repeating function has been removed on firmware version 1.0.0.58 due to less security.
If you like the feature, you will need to downgrade the firmware.
Message 2 of 6
All Replies
ElaineM
Message 2 of 6
rroche
Thank you so much Elaine.  How do I downgrade the firmware?  And where to i get the old file?
Message 3 of 6
ElaineM
You're welcome.
The instructions and the file can be downloaded here
Message 4 of 6
Rjl907
I have the same router and I'm trying to downgrade but the website I'm told to go to to make the changes never comes up on any Web browser I pull up and can't change it
Message 5 of 6
ElaineM
@Rjl907 What website? Are you talking about the www.routerlogin.net?
See the articles below on how you can access it.
If you cannot login to your router
Why can’t I access routerlogin.com or routerlogin.net?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 14449 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
