JC21
Apr 05, 2018Aspirant
Disney Circle stops working frequently on R7000
Disney Circle Premium stops working frequently on R7000. The only way to fix it, that I've found, is to restart the router. My family is not happy, as they are often blocked from the internet. ...
JC21
I should have pointed out that I'm on the latest Netgear firmware, and that when Circle stops working, the profiles with a bed time set are not able to access the internet/network during normal hours where they normally would be able to do so (just in case there was any confusion : )
DexterJB
Apr 10, 2018NETGEAR Moderator
- PmaherAug 27, 2018AspirantI cannot reconnect, but it was working fine the other day.
- DexterJBAug 29, 2018NETGEAR Moderator
Hi Pmaher,
Welcome to the community!
We recommend starting a new thread with a more detailed description of your concern and the steps that you have taken along with the results. OP confirmed that latest firmware version was able to resolve the issue.
Dexter
Community Team
- martynzNov 01, 2018Star
Disney circle does NOT work correctly with the latest firmware as at 2 Nov 2018
The latest firmware is V1.3.1.44_10.1.23
I am a software developer , ex-test analyst - and father of 4 children.
Every time you reboot / power cycle the router , Circle switches off. it also has intermittent faults where you cannot connect to it ( I cannot re-create these consistently but they are definietely happening.
I have taken someone elses advice and completely erased everything back to factory settings and re-entered everything from scratch. this does NOT solve the problem , so as far as the disney circle goes with the Nighthawk R7000P goes , it is completely useless - at least if you want to protect your children.
What a $%%%$ waste of money.
