JC21
Apr 05, 2018Aspirant
Disney Circle stops working frequently on R7000
Disney Circle Premium stops working frequently on R7000. The only way to fix it, that I've found, is to restart the router. My family is not happy, as they are often blocked from the internet. ...
DexterJB
Nov 06, 2018NETGEAR Moderator
martynz
Nov 06, 2018Star
Hi Dexter.
I have replied ( and copied below )
Hi Dexter.
I am sorry but I have changed to Linksys / Untangle. While you might be able to fix it , there is no guarantee that it won't break in the future.
While Disney Circle obviously do take children's safety seriously on the internet , it is not a priority for Netgear ( otherwise you would have picked up something like this in testing and it wouldn't leave a "gaping hole" for children to be exposed to the raw internet ) . Also the fact that there have been quite a few issues reported by people ( and I would say many more not reported ) .
I am sorry , but I am not prepared to go back and fix it , I have moved to a more stable system. while it doesn't have the flexibility of an app , it does support the granular security levels to keep children safe.
Kind Regards
Martin
