Dogdad7's avatar
Dogdad7
Filter options changed?
My router is a R7000 and noticed that the 2.4 and 5 filter options are no longer on my app and seem to have been replaced with wired or wireless. Any way to change this back or is it a netgear change?
  • FURRYe38's avatar
    What filter options are you referring too?
    What app are you referring too?
    What FW version are you using?
    • Dogdad7's avatar
      Dogdad7
      The filters that used to show 2.4 and 5 now show as wired or wireless on the device connected part of the  nighthawk app. My FV is v1.0.11.126
      • FURRYe38's avatar
        Probably something that was removed from the app.
