careerken's avatar
careerken
Follower
Feb 21, 2024
firmware update
Trying to update but Nighthawk app doesn't support AC3160. How do I get this and other updates accomplished, or am I better off replacing the router? It's been working fine until very recently. Thanks for any advice you can offer.
  • michaelkenward's avatar
    michaelkenward
    There is no such thing as an AC3160. It isn't even a valid "speed" designation. That would be something like AC3600.
    Look at the label on the thing fr a model number
    Then visit the support pages:
    Support | NETGEAR
    That page will also firmware your device.
    Check the section in the manual on updating the firmware.
    Or read this:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
      • schumaku's avatar
        schumaku
        michaelkenward wrote:
        schumaku wrote:
        AC3160 is a popular, older 1x1 Intel WiFi Client Intel® Dual Band Wireless-AC 3160 - very useful for driver updates is the Intel® Driver & Support Assistant btw.
        Aha. Nothing to do with Netgear. Certainly beyond the scope of the Nighthawk app.
        Whatever people are asking sometimes 8-)
        This is what Gemini does create on the subject:
        The Intel® Dual Band Wireless-AC 3160 is a Wi-Fi adapter that supports both 2.4 GHz and 5 GHz bands. While it doesn't have separate firmware itself, it relies on drivers and BIOS updates to function properly. So, depending on what you're looking for, here are some options:
        Drivers:
        BIOS updates:
        • Manufacturer's website: BIOS updates are essential for ensuring compatibility between your hardware and software. Check your device manufacturer's website for the latest BIOS update for your system. This might indirectly update the firmware for the AC3160 adapter as well.
        Additional information:
        Things to keep in mind:
        • Before updating drivers or BIOS, make sure you back up your important data.
        • Only download drivers and BIOS updates from trusted sources.
        • Read the installation instructions carefully before proceeding.
        I hope this information helps! Let me know if you have any other questions.
  • plemans's avatar
    Or to throw another one out there, are you referring to the C7800 which is an AC3200 device that the app can't update because its a modem/router combo device?
    Without more feedback from the OP, tough to know what they have, what they're trying to update, or whats going on at all.
