Kazuss
Dec 21, 2017Aspirant
firmware upgreade to 6.9.1 from 6.2.2
Hello,
I have an RNDU2000 device that I use since the news. I have never updated the firmware and currently I have 6.2.2 versions
A message is displayed about available updates to version 6.9.1, but the description of the update indicates that I should first go to 6.3.5, then to 6.5.2 and only to 6.9.1.
however, I can not find these intermediate updates 6.3.x and 6.5.x. where can I download them?
Can there be data problems on the disks during the update? I have enough important documents and I can not lose them.
Regards
Kazuss
You refer to the RNDU2000. That is a ReadyNAS box, but you have put your message in the forum section for Home Networking Apps. It would be better in the ReadyNAS section:
ReadyNAS Network Storage - NETGEAR Communities
There is a manual and support for the RNDU2000 somewhere at the end of this link:
>>>> RNDU2000 (ReadyNAS Ultra 2) | Product | Support | NETGEAR <<<<
I see nothing about firmware there. Are you sure this is the device you need to update?
- KazussAspirant
Looks more like an OS update than firmware.
Try this:
Plug in your model number, RNDU2000.
