xwagner
Jul 17, 2025Follower
Forced to use Nighthawk app to set up new hardware and it sucks out loud
I tried to set up the modem/router manually, following the printed instructions to the letter. No good. Had to download the app, which I wanted to avoid for precisely the experience I had. Who wrote ...
Jul 18, 2025Guru - Experienced User
It is not required to use the NH app to setup. For routers and gateway modems, can use there web page:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
I use this all the time.
xwagner wrote:I tried to set up the modem/router manually, following the printed instructions to the letter. No good. Had to download the app, which I wanted to avoid for precisely the experience I had. Who wrote this app? Did ANYONE test it? Maddening. Wanders in circles. I finally called the support number, waited on hold, someone with an accent that suggested they were Not From Around Here answer and my call was immediately cut off. I am livid.
