abuehrlen's avatar
Aug 03, 2014
Genie Apps not accepting router password
I get " Login Failed. Please re-enter the correct admin password for your NETGEAR router." I get that on both mobile and desktop versions of genie. Any help anyone can give would be greatly appreciated.
  • The Genie app does not work for me if IPv6 is enabled on the router. Did you enable IPv6 on the router by any chance? If so try disabling it.
  • [QUOTE=gartaud;479838]The Genie app does not work for me if IPv6 is enabled on the router. Did you enable IPv6 on the router by any chance? If so try disabling it.[/QUO
    I didnt enable it. I checked to be sure and its disabled.
