Darryl_Gittins
Sep 10, 2017Tutor
Genie Cannot change access control filter level for certain devices
When I use the Android Genie app, when i try to change the filter level for certain devices, I get the error "Setting Failed". The PC app also fails to change the filter level, but I do not receive ...
DexterJB
Sep 18, 2017NETGEAR Moderator
Hi Darryl_Gittins,
1. What is the firmware version of the router?
2. What is the Genie version on the PC and the mobile device?
3. Have you tried resetting the router?
Dexter
Community Team
Darryl_Gittins
Sep 20, 2017Tutor
Thank you for your reply. Here are my answers:
- What is the firmware version of the router?
Hardware Version R7000
Firmware Version V1.0.9.6_1.2.19
GUI Language Version V1.0.9.6_2.1.38.1
- What is the Genie version on the PC and the mobile device?
Genie version Version 2.4.38, and I'm using the PC app, the iOS app, and the Android app. They all fail to update settings for the same certain devices. They all are able to update settings for the same other devices. All three apps fail and succede with the identical devices in identical ways.
- Have you tried resetting the router?
Yes, several times.
