Darryl_Gittins
Sep 10, 2017Tutor
Genie Cannot change access control filter level for certain devices
When I use the Android Genie app, when i try to change the filter level for certain devices, I get the error "Setting Failed". The PC app also fails to change the filter level, but I do not receive ...
DexterJB
Sep 18, 2017NETGEAR Moderator
Hi Darryl_Gittins,
1. What is the firmware version of the router?
2. What is the Genie version on the PC and the mobile device?
3. Have you tried resetting the router?
Dexter
Community Team
DexterJB
Sep 20, 2017NETGEAR Moderator
Hi Darryl_Gittins,
I have sent you a message. Please check your inbox.
Dexter
Community Team
- BCoopDec 16, 2017InitiateI am having the same issue. May I get the solution. I have the iOS app. Thanks!
- chielvApr 30, 2018Initiate
Curious to this solution, as I have the exact same issue
- maethlinMay 23, 2018Initiate
EXACT same issue here.
This used to work fine.
Now I cannot change via mobile app or PC app.
Mobile app says "Setting Failed", PC app just silently does NOTHING.
- menbrouwJun 04, 2018Initiate
Same for me here. Curious to the solution as I have the exact problem.
Thanks in advance!
- Darryl_GittinsJun 04, 2018Tutor
Don't hold your breath. It's a crap-app and Netgear has shown no interest whatsoever in fixing it.
