Darryl_Gittins
Sep 10, 2017Tutor
Genie Cannot change access control filter level for certain devices
When I use the Android Genie app, when i try to change the filter level for certain devices, I get the error "Setting Failed". The PC app also fails to change the filter level, but I do not receive ...
DexterJB
Sep 20, 2017NETGEAR Moderator
Hi Darryl_Gittins,
I have sent you a message. Please check your inbox.
Dexter
Community Team
BCoop
Dec 16, 2017Initiate
I am having the same issue. May I get the solution. I have the iOS app. Thanks!
