thomasf
Dec 08, 2013Follower
Genie Problem
This may be the wrong place to discuss the Genie product but I would appreciate some help.
Using Windows 8.1 through the Netgear D6200 to the Apple Airplay Express. The music drops are annoying and I have found that the problem may be exacerbated by the Genie software.
On the Windows page "devices and printers" there is an item "Genie Media Servers" and if I close out the system and then restart there will be two or "Genie Media Servers" and then three. The more replications of the Genie Media Servers icon the more the problem exist. When I delete all but one of the Genie Media Servers the system works fairly well.
What is this function and how does one control it?
Am I the first to have this problem?
Tom F
- jfmoenAspirant:mad:Yup same problem...I have about 8 of them now....they all work, a new one appears everytime I reset the modem .... sorry no idea either
- theoldfarterAspirantI have 47 showing. There is a bug in the Genie, for sure. How about it Netgear, can you post here to advise what will be done to fix it?
- theoldfarterAspirantSorry, forgot to add that I am using the D6300.
There is not a forum for that exact model here. - FairytailVirtuosoDid you encounter the same problem with other operating systems? Let me try this if I have the same problem.
- theoldfarterAspirantInstalled it on another laptop running Windows 7 (x64) Ultimate.
Genie does not show in devices & printers. Does not show after a restart of laptop or a restart of the D6300.
On my Windows 8.1 (x64) laptop, I removed all instances on Genie except one.
Restarted the D6300 a couple of times but doing that did not add any more genie instances.
Restarted my 8.1 laptop & another instance of the Genie appeared in devices & printers. Every time I restart my laptop, another Genie icon appears.
It looks like there is an integration glitch.
I will wait until you reply & if no solution is forthcoming, I will email Netgear.
Thanks. - FairytailVirtuosoWith the results of your isolation, it shows that it has something to do with Windows 8.1 and NETGEAR Genie since it works fine or you were not able to reproduce the same problem with the Windows 7. This is clear now. I might try this one to see I am able to reproduce it.
- DevorLuminaryDo you have a specific need for the Desktop Genie? If not, just uninstall it.
- theoldfarterAspirantNo, I don't use it. It would be nice to have it working correctly with Windows 8.1 though.
- FairytailVirtuosoDo you have the latest Genie software version or have you tried a different Genie version?
- theoldfarterAspirantGood idea! I have v2.3.1.12 & was able to find v2.3.1.13
I removed all Genie icons in Devices & Printers & uninstalled latest version 2.3.1.16
Both earlier versions did not install extra icons in Devices & Printers.
Does anyone have links to versions 14 & 15, so I can try them?
Seeing v12 & 13 did not add icons into Devices & Printers, that points to a glitch in version 16, in my opinion.
