Ghurxa's avatar
Ghurxa
How do I use the QoS in WNR2000v5
I'm trying to set up my laptop in genie to have it set set to the highest priority, but they're all set to normal and i don't know how to change that. Any suggestions?
Much appreciated. (:
  • Follow the instructions on page 37 in the manual.  Here is a direct link.
    • Ghurxa's avatar
      Ghurxa
      Priority stays as normal when i change it. I click the bubble, set priority to highest, then click apply. When it's done, it stays the same. Doesn't change.
    • Ghurxa's avatar
      Ghurxa
      I believe i got it. Under the mac device list, it says normal still, but under QoS rules it is under "highest".
      • TheEther's avatar
        TheEther
        Guru
        You're good.  The fields under MAC device list are used to add a new rule.
