Velcnet
Apr 13, 2022Aspirant
How to bring device back remotely
Hi. I am using Nighthawk app to manage devices remotely and deleted one of the device mistakenly.
Is it possible somehow bring device back to Nighthawk iOS app if I am not able to go to this apartment to connect device's wifi?
Which app? Android? iPhone?
How did you do that?
If you hit "Pause" can't you just "Resume"?
- VelcnetAspirant
I am asking about iOS Netgear Nighthawk application. Here we have 'cloud' button on top left to choose device that can be managed locally or remotely. And here under every device we have ... menu and delete option. So I mistakenly delete remote device from my cloud account. And now I need to bring it back somehow remotely.
Ah. So you did not disable a device on the router.
You deleted the device that you manage. Or was the action "Remove Device"? (I couldn't see any "delete" in there. ) That's what I see in Android.
I suspect that you have disabled Remote Management on the router itself.
If so, the only way back in is probably to set it again on the router.
