JTrumm's avatar
JTrumm
Follower
Mar 10, 2025
How to change security setting on R7000p?
I need help to change the security setting on a R7000P router. I downloaded a new version of the Nighthawk App on my iphone 13. I thought I could change the setting in that app but I don't see how to do it.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which security setting? WiFi?
    Why do upoou need to change it?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Specify Basic WiFi Settings.
    You may have done that already. I can't tell from your message.
    Just another user with time on their hands.
