konagal
Jan 23, 2018Aspirant
I cannot get a confirmation email to start Remote Access on my iPhone
I have the R8900 NighthawkX19-AD7000 which IS supposed to be supported my the Netgear Genie remote access. But, every time I try to use it I do not get a confirmation email. Yes I do check my spam fo...
michaelkenward
Jan 24, 2018Guru - Experienced User
konagal wrote:
But, every time I try to use it I do not get a confirmation email. Yes I do check my spam folder. When I press "resend email" I get an error message saying "Unknown Error" I contacted support and they had me delete the app then re-download it.
What are you using to set this up?
The iPhone app?
