konagal
Jan 23, 2018Aspirant
I cannot get a confirmation email to start Remote Access on my iPhone
I have the R8900 NighthawkX19-AD7000 which IS supposed to be supported my the Netgear Genie remote access. But, every time I try to use it I do not get a confirmation email. Yes I do check my spam fo...
michaelkenward
Jan 24, 2018Guru - Experienced User
konagal wrote:
But, every time I try to use it I do not get a confirmation email. Yes I do check my spam folder. When I press "resend email" I get an error message saying "Unknown Error" I contacted support and they had me delete the app then re-download it.
What are you using to set this up?
The iPhone app?
konagal
Jan 24, 2018Aspirant
Yes the iPhone app. I also tried it on my iPad and still got the same errors.
- cilla0925Mar 02, 2018AspirantDid you figure it out? Having this issue now. :(
- konagalMar 02, 2018Aspirant
No. I returned the router
- michaelkenwardMar 03, 2018Guru - Experienced User
It seems from other recent messages that some people have been trying to set up remote access on portable devices without realising that you have to initiate the process from the router's control interface. The portable genie only comes into play after you set it up on the device itself.
The manual explains this, but perhaps not as clearly as it could.
In the case of the R8900, the details of how to set up remote control are on page 86 of the manual, somewhere at the end of this link:
>> Click here >> R8900 | Product | Support | NETGEAR << Click here <<
You may have been through all that, this is intended to guide anyone who turns up here and searches the forum for answers to the same question.
