RMC60
Jul 13, 2022Aspirant
I cannot get the Nighthawk app to work with my new c7000v2 router.
Aloha, I have a number of questions here. I apologize in advance, as I am definitely not a tech expert. (1.) I just purchased and installed a new Nighthawk c7000v modem-router combo. I need to acc...
michaelkenward
Jul 15, 2022Guru - Experienced User
RMC60 wrote:
Is the Nighthawk app compatible with the c7000v2?
Yes. Not quite sure that the SOLVED flag is accurate.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
In other words, the Nighthawk app supports routers, modem/routers, wifi extenders, mobile wifi and a raft of things.
The C7000v2 is also in there.
It says that my firmware is out of date, but I will call my ISP, and see if they can fix that. (4.)
That's an old bug on the iOS app itself that Netgear is too idle/incompetent to fix. Neither you nor Netgear has any control over the firmware on the C7000v2 .
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
Note the Netgear response:
Re: Nighthawk app same "firmware not updated" when... - NETGEAR Communities
Could that be the problem that prevents being able to connect with the app?
Unlikely, tell us a bit more about that problem.
What are you doing and where does it go wrong?
