msnet
Oct 16, 2019Guide
I cannot login to nighthawk with correct admin password
I cannot log into Nighthawk app of my smartphone using correct password. I checked my password by loging into Netgear account using Chrome browser. I checked that the password I used in the loging in process. It failed. What can I do. Thank you.
- msnetGuide
Thanks. My phone is pixel 3, an Android phone.
- msnetGuide
No, I have not reinstalled the app. What happened was that I changed my phone to Pixel 3 only a month ago. I tried every which way other than reinstalling it. I will try to reinstall the app again and see what will happen.
- msnetGuide
Hi Dexter,
I reinstalled the Nighthawk app. and tried to log in. But failed.
msnet wrote:I cannot log into Nighthawk app of my smartphone using correct password.
Here must be confusion again. Are you aware there are two different username and password?
msnet wrote:Subject: I cannot login to nighthawk with correct admin password
The admin acount and the password is used for the local authentication for the local router access.
The Netgear account can be used once the router is bound to the Netger cloud and associated to your Netgear account, or for example also for the Community access here, the https://my.netgear.com/ ...
The password for these is not the same.
- msnetGuide
Off course I used my email address and the password for Netear to log into the Nighthawk app. Then, when the "user: admin" and was asked for local password. I inputed the local password.
The "password for Net[g]ear" could be one of several things: MyNetgear, this Community or the "Remote Management" system, which goes through Dynamic DNS. Sometimes these use the same credentials, sometimes not.
The mobile apps rely on the third of these.
Of course, if you are using an app locally, the first login is to the wifi.
If the idea is to get into the router itself to change settings, then experienced users avoid the apps. They dive in locally with the browser graphical user interface (GUI). Alternatively, they use the desktop genie as a way in.
If you want the desktop genie for Windows start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
