ciscokid624
May 07, 2025Aspirant
I have a R9000 Netgear Nighthawk Router
Hello. I have a R9000 Netgear Nighthawk Router and since yesterday after doing a factory reset have been unable to login from the app on iOS. Been fine since 2021 but not anymore. My phone has nothin...
- May 14, 2025
It's just logging in to the app in having an issue with and your link only says how to report a bug? I need the timeout issue resolved as I still can't login. Thank you
May 07, 2025Guru - Experienced User
FYI: https://community.netgear.com/t5/Nighthawk-App/Nighthawk-App-Timed-out-Issue/td-p/2454376
If you need to setup the router, use a PC and web browser for this at this time: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- ciscokid624May 14, 2025Aspirant
- FURRYe38May 15, 2025Guru - Experienced User
You'll need to use the routers web page in a web browser on PC or laptop to access the router until the NH app issue has been fixed by NG.
