Shtk12
Sep 24, 2017Aspirant
I have Netgear R7000, when I do speed test on my phone with Netgear Up apps, always says error
Shtk12
Yes, speedtest app has been working on my phone, but not on Netgear Up apps. Is it not compatible with R7000 router ?
DexterJB
Oct 25, 2017NETGEAR Moderator
Hi Shtk12,
1.What is the firmware version of the router?
2. Have you tried uninstalling and re-installing the app?
3. Have you tried using another device (iOS, Android)?
Dexter
Community Team
- DexterJBOct 30, 2017NETGEAR Moderator
Hi Shtk12,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- Shtk12Oct 31, 2017Aspirant
Hello,
I still have the same issue, and I uninstalled/reinstalled Netgear Up apps many times with a new set up when reinstalled. The router firmware is V1.0.9.12_1.2.23. I have no problem with other speedtest apps
Sincerely,
Shtk12
- DexterJBNov 02, 2017NETGEAR Moderator
Hi Shtk12,
I was able to do my own test and did not encounter any issues.
1. What is the model of the mobile device that you are using and what is the OS version?
2. Please try using another mobile device (Android, iOS) and check if the issue persists.
3. On which band (2.4GHz or 5Ghz) is the device connected?
DexterCommunity Team
- Shtk12Nov 06, 2017Aspirant
Hello,
I have BLU phone, model Life One X, android version 6.0, and I tried on Alcatel 30plus, android version 7.0, they both attached with 2.4 ghz band @ the router, problem persists
Sincerely,
Shtk12
