dsn's avatar
dsn
Tutor
Dec 24, 2015
Installed Genie for Android, now phone won't connect to wifi network
OK, this is a strange one. About a month ago I installed a new R6400 router. Assigned the same SSID and password that were already in use so I wouldn't have to reconfigure about a dozen devices. Everything, including two Galaxy S5 phones, worked flawlessly.
Then, after a week or so, I installed the Genie Android app on one of the Galaxy S5 phones. Started the app, successfully connected to the router, and everything still seemed to be working as it should. However, the next day, the phone that had Genie installed quit connecting to the 2.4 GHz wifi. (Every other device, including the other identical phone, continued working fine.) It would hang at the "obtaining IP address" step, then show an unhelpful message about the AP not being in use. Uninstalling the Genie app and rebooting the phone did nothing. The only thing that would restore the wifi connection was found on a Verizon support forum: Turn off wifi on the phone; shut down phone; remove battery and SIM card; then reinstall SIM card and battery and power on phone. The 2.4 GHz wifi connection then started working again, and worked perfectly for several weeks.
To see if I could duplicate the issue, I again installed, but did not run, the Genie Android app. The phone continued to connect to wifi perfectly. After several days I ran the Genie app, and sure enough, within an hour or two the phone's wifi again quit connecting. This tells me that the Genie app is the cause of this problem. I'm just leaving the app off both smart phones until I can find a solution.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi dsn,
    1. What is the Android version of your Galaxy S5?
    2. What is the version on the NETGEAR Genie app that you have installed?
    3. Can you please provide the link for the Verizon forum post?
    Dexter
    Community Team
    • dsn's avatar
      dsn
      Tutor
      1. Android 5.0
      2. Genie version 2.4.26
      3. Link is here. The issue in that thread doesn't appear to involve the router or router app, but I stumbled on that thread while searching on my wifi connection problem. The solution in the second post - turn off wifi/power down/remove sim card - is the only workaround that has restored the wifi connection on my phone.
      Before I posted here I duplicated the problem twice, but after I posted I again lost the wifi connection without ever opening the Genie app, so now I'm not sure what's going on. I never saw this problem with my previous router, a WNDR3800. The problem first showed up a week or two after I upgraded to a R6400. I don't see how it's a router issue though, because all other devices -- wireless printer, tablet, laptop, Roku, smart TV -- have all been working flawlessly.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi dsn,
        1. Were you able to replicate the issue with the other Galaxy S5 phone?
        2. Have you tried it with another Android device?
        Dexter
        Community Team
