GrinningSharky
Sep 29, 2026Guide
IP Address Cut Off
I noticed the IP addresses in the iOS nighthawk app get cutoff. This only happens when using a non-default base IP. Can this be added to be addressed in a future update? For example: 192.16...
Sep 30, 2026Guru - Experienced User
GrinningSharky wrote:I noticed the IP addresses in the iOS nighthawk app get cutoff
Does this resolve if you reduce the text size a bit in the phone settings (settings -> display & brightness and accessibility-> display & text size are the two places to check).
- GrinningSharkyOct 12, 2026Guide
I am already using the default font size and not the enlarged font/UI. Enlarged fonts are off.
- FURRYe38Oct 12, 2026Guru - Experienced User
