Fedaykyn
Jul 12, 2016Aspirant
Is lan bridge mode on D1500 possible?
I've always used cheap modem/router as bridged modem connected to a better router, but I noticed that in Netgear D1500 is not possible to do so. I'm not interested in wifi bridge, just using it like a simple cabled modem. Is that possible with some specific firmware? (I'd like to solve this also because my main modem/router doesn't reach the same speed, this is the best modem I've tried on my line, what chip does it use? thanks)
- Anonymous
- MightyGorathAspirant
Disabling DCHP doesn't seem to work. Even with it switched off, the router still assigns IP adresses.
- FedaykynAspirant
MightyGorath have you solved it?
- FedaykynAspirant
I can try but won't it work still as router?
