Vgangadh's avatar
Vgangadh
Is netgear Ac3000 model 7900 compatible with Disney's circle?
I am looking to purchase the Circle for parental controls. I checked the following site https://support.meetcircle.com/is-my-router-compatible-with-circle for compatibility of netgear routers and found that  AC3200 Nighthawk X8 R8000 is supported. The router I have seems to be one version prior to the one that is tested as per the Circle support website.
Has someonne successfully added parental controls with the Netgear R7900 router ?
Thanks
  • We’re u able to get this resolved? I have the same model and it doesn’t seem to be working for me either
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Vgangadh,
    The Circle hardware should work with the vast majority of routers including the R7900 as stated on the link. That model also shares a lot of hardware similarity to the R8000.
    Dexter
    Community Team
