hademtel
Oct 15, 2016Aspirant
Linking Xbox One Wired Connection NAT issues
Hello! I have a NETGEAR Genie R6400 wireless router. I have hooked up my Xbox One in the past when I first purchased this router and I had this same issue. When the Xbox is wired directly to the ...
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi hademtel,
I would recommend doing address reservation through the router for the XBOX instead of manually setting a static IP. Once you have reserved a specific IP for the XBOX then you can redo the port forwarding directing to its IP. This is a way to ensure that the XBOX will consistently get the same IP address from the router and have the forwarded ports directed to it. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
- hademtelOct 29, 2016Aspirant
Hello! Thank you for your quick response! Sorry I've taken a while, I finally tried this and was not successful. I've tried severl things to try and fix this problem, but have made no progress at all.
Here's whay I've tried.
Setting a static IP fo the XBOX and forwarding all the ports to that IP
Creating a DMZ around that IP
Turning UPnP on and off
Enabling VLAN/Bridge Setup to the port my XBOX is wired to
Changing my Internet Connection type to "Pass Through"
Tried to trigger the ports instead of forward them
And now I've tried to redo the IP and the Port forwarding and it's giving me an error message that reads "The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type"
Any and all help or responses again, are very welcomed. I'm about out of things to try. I don't know what else I could change on my router to fix this issue.
Thanks,
Hademtel
- Retired_MemberOct 29, 2016
reset to defaults
reserve IP
use PORT triggering
- hademtelOct 30, 2016Aspirant
Thank you for your response searay! however, this did not work either. I triggered all the ports that were listed online as ports the XBOX needed, and that did nothing. Then I tried to trigger them straight to the IP of the XBOX, still no luck. Any other suggestions?
