hademtel
Oct 15, 2016Aspirant
Linking Xbox One Wired Connection NAT issues
Hello! I have a NETGEAR Genie R6400 wireless router. I have hooked up my Xbox One in the past when I first purchased this router and I had this same issue. When the Xbox is wired directly to the ...
Retired_Member
Oct 29, 2016reset to defaults
reserve IP
use PORT triggering
hademtel
Oct 30, 2016Aspirant
Thank you for your response searay! however, this did not work either. I triggered all the ports that were listed online as ports the XBOX needed, and that did nothing. Then I tried to trigger them straight to the IP of the XBOX, still no luck. Any other suggestions?
- Retired_MemberOct 30, 2016
You're Welcome!
there are several FW versions you could try a different one
- DexterJBNov 01, 2016NETGEAR Moderator
Hi hademtel,
1. If setting DMZ to the XBOX does not result in any changes in the NAT type, try bypassing the router and hard wiring the XBOX straight to the modem to check if the issue remains for isolation purposes.
2. As for encountering the conflict error when port forwarding, try disabling UPnP first then do the port forwarding.
3. Please do Address Reservation for the XBOX first before doing the port forward.
4. As suggested by searay, please try other firmware versions.
Dexter
Community Team
