BizzyM
Mar 07, 2022Aspirant
"Logon Timed out" after restarting R6700v3 via app
Model: R6700v3
FW: V1.0.4.122_10.0.95
App ver: 2.14.0.1930 (1/16/22)
Using app on OnePlus 8 and LG V30+
Logged into app and reset router, not a firmware update. After rebooting, app presents Login screen and doesn't work with phone biometrics suddenly. password not working. App keeps showing a "Logon timed out" message every time. Can log in via web interface using same password.
Rebooted phone: same problems.
Manually restarted router: same problems.
Reset password via Router's web interface: same problems
Searched topics and saw the Time Zone suggestion. Time Zone is set correctly and time/date matches both phones that the app is being run on.
What's the trick?
So only the app isn't working?
If you're on android, go into it and clear cache/data.
If you're on iOS, uninstall the app, reboot your phone, and reinstall it.
- BizzyMAspirant
Tried clearing cache, data, uninstalled, reinstalled. Updated firmware to V1.0.4.126_10.0.102 and still giving me issues with the login. I'm still able to log into the router from a browser with the same password.
I've seen quite a few posts with the app not working properly. I'd wait on app updates to see if that fixes it.
That says you "reset router". Your subject says "after restarting R6700v3 via app". Which was it?
They do different things. I'm guessing restart, but you never know.
- BizzyMAspirant
Sorry, I did mean restart, not reset.
