ciscokid624
May 08, 2025Aspirant
LOGON TIMED OUT. PLEASE TRY AGAIN.
Hello Netgear. Having a difficult time as I cannot login to the app anymore because of immediate timeout? What is happening and how to change it fix this issue? I can sheet logon on a desktop but thi...
- May 27, 2025
App working fine again. Thank you
May 27, 2025Guru - Experienced User
NH app was updated over this past weekend for Apple devices. Check the Apple Store for the update. Still waiting on Android.
I was able to get logged in initially with Local Only mode, however enabling Anywhere Access, seems to break the local only connection.
Selecting Settings in the App gets me a spinning circle and loading and never completes.
Closing and reopening the app, gets me a failure to connect in the app or select another router to connect too.
App still needs some work.
