PD72
Nov 20, 2017Follower
Loss of internet after enabling Circle by Disney on R7000
I enabled Circle by Disney on the R7000 but then started experiencing internet dropouts. I have rebooted the router and the problem goes away for about an hour before dropping the internet again. ...
Inquisitor
Nov 20, 2017Aspirant
Similar problem - Circle setup is confusing - limited to Android or iPhone App with poor documentation. Tried it anyway last night and it seemed to be working OK. Woke up with total internet failure on WIFI side, was unable to connect to the router or even ping the router from WIFI. DHCP wasn't working on WIFI.
Fix: Connect using wired connection to router. Disabled Circle then reboot router. Your WIFI should be restored. At least that worked for me.
I'll try Circle again later today or tomorrow and see if it is a bug, or hopefully just my user error.
