JimShane's avatar
Oct 21, 2021
MK63: "Issues Connecting with [mesh network]" (but access to internet is fine throughout house
Let me preface this with - access using t he Nighthawk Mesh system is working just fine throughout our house. I was thinking of adding a couple of new satellites. So, I went on my android phone to the Nighthawk app. I used to go on this app all the time to see what was connected to what satellite (but I haven't used it for a while - and I have a new phone since I last looked (I think).  I have 4 teenagers, and my wife and I - we use AT&T fiberoptic 1G service.
When I go into the nighthawk App, after searching for a number of minutes, I get the message "Issues connecting with [the name of our network]" Go to Settings > WIFI and join your Router's WiFi Network. (Now, I tried this, and I'm not sure whether I should put in the name of the AT&T network that is our Router, or the name of the Mesh Network that I set up when I got Nighthwawk) I've tried both.
I've tried "Try again" multiple times.
I tried "New System Setup".
and I've tried "Connect via Anywhere Access" (when I do this, It shows me a green dot with the "MR60" name, but no other options - so I don't know what I'm supposed to do with it. (It doesn't show any satellites). Only the picture of the MR60 box, a green dot, the serial number - and the three vertical dots with the option to "Remove device" So, now, I don't know how to proceed. Any suggestions?
Should I uninstall the Nighthawk App, and try reinstalling it?
Nighthawk App.  v2.12.0.1770
MK63 - AX1800
  • After having this problem since October, I just left it alone.   With a bunch of teens at home, I didn't want to take a chance on upsetting the internet throughout our house.  The system was working, I just couldn't use the Nighthawk App to access or change the system.
    I went into the app on my phone today and try to tackle this again.  I really wanted to add a couple of new sattelites to the system, but I couldn't do that without that access.
    And to my amazement, the app worked.   I had tried this app dozens of times without it working - but today it worked.
    I have no idea what happened, nor what changed.
    I can see all 28 devices attached.  I can see the six satelites.     the only thing that doesn't work is the "Internet Speed" (I don't remember this as being an option before.)    We have a 1Gbps system.
  • FURRYe38's avatar
    Can you access the MR systems web page ok with a PC and web browser?
    I recommend disabling Connect via Anywhere Access in the app if you can see this option and it's available.
    Yes you can uninstall and re-install the app.
    Try installing the app on a different mobile device.
    • JimShane's avatar
      JimShane
      Guide
      I did uninstall and reinstall Nighthawk App.  The App still says "Issues connecting..."
      It does allow me to use AnywhereAccess.   It shows a green dot and the "MR60".  Then it box below comes up that says "Updating Device List".   Ater several minutes,  there are no other devices that appear.   If I click back on the "MR60", then it just cycles through "Connecting to", and dones the "Updating Device List" again.
      With my old phone - it used to show me all six satellites - and then all the devices connected to them.  I know all the satellites are working - I just have no way to see them anymore
      • JimShane's avatar
        JimShane
        Guide
        And, I was finally able to use my old phone to see if the Nighthawk App worked on that on.  (It used to work when I used that one (it was an android Samsung S7).   Well, I stopped using it because the touchscreen didn't work any longer.   So, I had a hard time figuring out how to get it to work.  But, I was able to connect a USB Mouse to allow me to access the old App.   It gives me the same issue - so it was not that something transferred incorrectly on the app.
        So, while my nighthawk mesh system works throughout our house just fine - I have no way to checking connected devices or adding new satellites.
        I'm hesitant to do a factory reset and have to redo all the setup since everything works.  But, if I don't get an answer here, it may come to that.
