Gwired
Dec 15, 2020Aspirant
MR60 and Two MS60 Satellites - keeps kicking off to 2.4GHz, DC's etc on V1.0.6.102_2.0.45
I have two MS60's as sattelites to 1 MR60. Continuously on V1.0.6.102_2.0.45 of the firmware I am getting kicked off the network. This issue I have seen in the forums for some time now.
Is there a fix coming is there anything I can do? In the past I would have trouble with my TV connecting then an upgrade occurred and now it works "meh" but always is connected. But now my PC's are DC's and bad networking all the time.
This experience with the 90 day support is really crappy service. Maybe I should get chat support until my warranty is up? That would be what I would do if I thought my products were any good.
This needs to be fixed!
- GwiredAspirant
If I should choose to downgrade my router to 1.0.4.98 there are two files one for the MS60's and one for the MR60. Is there an order that I should do them in?
- Christian_RNETGEAR Employee Retired
Hi Gwired,
I have responded to your message.
Regards,Christian
- GwiredAspirant
Ok I did that and I am still having the issues.
Whenever I connect to Stadia specifically I can force the disconnects to happen.
When I run pings on various machines it is different but it is the same.
Pinging 172.16.0.1 with 32 bytes of data
Reply from 172.16.0.1: bytes=32 time=3ms TTL=64
Reply from 172.16.0.1: bytes=32 time=4ms TTL=64
Reply from 172.16.0.1: bytes=32 time=27ms TTL=64
Reply from 172.16.0.1: bytes=32 time=2ms TTL=64
Reply from 172.16.0.1: bytes=32 time=6ms TTL=64Different computers are seeing this differently though.
On this PC I am on I am seeing delays as high as 43ms. On another PC I am seeing them as high as 1357ms but average high is 112ms.
I can't help but think this is the router. These are all on Wireless AC. Eventually, when specifically running a high streaming content it will disconnect. This is on an Intel AC7260 which I know has problems in Windows but I switched to Linux and it seems to have the same issue. The systems are negotiating 5Ghz and 760Mbs connections but I am only seeing about 130Mb/s for a few seconds. Even SpeedTest.net has kicked it off the network / kicked it down to 2.4Ghz.
