FriendComputer
Aug 23, 2025Follower
My Nighthawk APP has gone to LOGIN FAILED
Yeah, that doesn't work either.
Aug 25, 2025Guru - Experienced User
What NG router is the app connecting too?
What mobile device do you have the app installed on?
Happens on a different device?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
