shanafan
May 02, 2020Apprentice
Netgear Armor doesn't show my router
Hello,
I went to check out Netgear Armor's website, and when I signed into my Netgear account, it doesn't show my XR500 router appear. It says "No routers associated with this account."
So, I went to my Nighthawk app on my phone, and verified it was the same account I just used on the website by logging in and out.
Thinking maybe my router wasn't registered, I went into Router Settings in the Nighthawk app and it says "Product registered" at the bottom.
Any idea why Netgear's Armor website doesn't show my router appear?
- shanafanApprentice
I have a Nighthawk XR500 router.
There are two places where you can look for help:
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR CommunitiesArmor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Thanks! I'll post there.
