spinninfree
Jul 12, 2016Guide
Netgear Genie App for Android - Login Remote access - No Internet connection detected.
Using a Samsung S5 - model #SM-G900T, with android version 6.0.1, security patch level is May 1, 2016 - and have had the Netgear Genie app - and have been using the Remote access feature on a daily basis with no problems - until yesterday.
Now, when trying to Login with Remote access - the error message No Internet connection detected, with the options *Close* or *Settings*. I do have an active data internet connection via T-Mobile and can access other services with no problem.
The Settings essentially takes me to my WiFi settings on the S5 - which is already set to Smart network switch between Wi-Fi and mobile networks, and also between 2.4 GHz and 5 GHz bands, to maintain a stable Internet connection.
Have even gone into the developer options settings and activated the Agressive Wi-Fi/cell handover option which states "When enabled, Wi-Fi will be more agressive in handing over the data connection to Cellular, when Wi-Fi signal is low" to see if that works and unfortunately this did not change the inability to Remote access my R7000 Nighthawk.
Any ideas or suggestions to remedy this?
Thanks - MC
I had a successful remote access this evening (not w/Beta) - with no error msg of No Internet connection detected. It appears that there has been a break through and that the app is behaving as it did prior to this error.
Hope the rest of you have the same success!
Spinninfree
- John6969Tutor
I have been having the exact same problem for the last few days. I tried uninstalling and reinstalling, clearing cache, clearing data, etc. Still not working. Help! It is the only way I have to keep my kids from playing games 24/7....
- mrekimfApprenticesame here
- Chita21Initiate
- Chita21InitiateHaving same problem for same reasons as above users. Please fix.. tried everything. Really need this feature back.
- appleshoeInitiate
Same Here....
- appleshoeInitiate
I bought the router in April and Netgear support wants $89 to help me resolve this new issue.
- SjoeInitiate
I am having the same problem with my Samsung Note, it was working fine till few days back (my free teck support expired few days prior to this issue) I did everything I could like update the app, reinstall the aap, register the app nothing seems working, please help.
Please note that the app work fine while I am connected to my home wifi. - Same. Galaxy S5 - 2 Netgear routers. No Remote Access. Local access works ok
Not sure if this has any bearing on things, as I am not a telephony engineer - but it seemed strange that the download speed from Netgear was this low - when the download and upload rate of my IP server is much higher ?
As to the current firmware - have thought about rolling back the firmware to the previous version - although this current inability to remote access via the App did not coincide with the update of the R7000 firmware- it may be worth a try to see if that has any bearing on this loss of remote access??
Any input from Netgear technicians would be greatly appreciated.
- GenieOqInitiate
having the same issue...remote option was working from anywhere from home until a few days back....now cannot get it to work even though i have downloaded the latest app and reset password multiple times...also need to get kids off pc
- dacloutierAspirant
Same here!
- Same. Seems netgear is not addressing this?!
